Re: "frozen" up
Posted by Dn-N-Tn on July 31, 2019 at 15:12:58 [URL] [DELETE] :
In Reply to: posted by Tom Keith on July 31, 2019 at 11:18:26:
Tom, If it were mine, I'd pull all the plugs and fill the cylinders with some good penetrating oil and let it sit with the plugs out a few days (keep them filled with the penetrating oil). Try every day or so to turn at the flywheel till it begins to move. I've done this, and sometimes it takes a few days to work. I'd be careful trying to tow it to make the engine turn if it is stuck. You could bend a connecting rod that way, good luck, Dennis
