Re: input shaft movement
Posted by paul appleton on July 29, 2019 at 07:33:46 [URL] [DELETE] :
In Reply to: Re: input shaft movement posted by K.LaRue-VA on July 29, 2019 at 07:15:10:
Unfortunately, there is a leak, albeit a small one. While I have it split I will do as you suggest. Can't wait till my manual gets here. Thanks for the comeback. Just for your info I print all of these suggestions and put them in a three-ring binder for further work. Beats running between home and shop to check the puter.
