Re: Troubled Ignition
Posted by Jon Rhee (RI) on July 18, 2019 at 16:34:19 [URL] [DELETE] :
In Reply to: Re: Troubled Ignition posted by Bob in KS on July 17, 2019 at 09:25:17:
I rechecked the resistor and the coil. I had to fight with the connection to the resistor but I got it down to 1.9 ohms. The coil about 2.2 ohms primary. That being said, I have a regular bright blue spark with a jumper from battery to coil. Seems slightly irregular through the dash wiring but still bright blue 1/4Ē arc. She starts rough then quits. Then wont really start again for a while. Iíve checked the rough timing which looks good. Good compression across the board.
Iím thinking theres got to be an issue in the carburetor then, unless an intake valve can be stuck in the closed position?
J
