Re: removal of rear wheel center disc
Posted by Lynn Patrick on July 18, 2019 at 08:23:02 [URL] [DELETE] :
In Reply to: Re: removal of rear wheel center disc posted by paul appleton on July 18, 2019 at 06:09:45:
BE SURE THE TRACTOR IS WELL BLOCKED!! Make sure the cribbing/blocking is overkill! The last thing you want is for the tractor to fall from all the pounding, etc needed.
As to remounting, scrape/clean the rust & crud from the inner circle of the rim & the flat part of the hub so the rim fits before mounting & it will slip right on.
