Re: 8n ford tractor clutch issue
Posted by r geiger on July 13, 2019 at 15:36:05 [URL] [DELETE] :
In Reply to: 8n ford tractor clutch issue posted by merwin woowdie on July 13, 2019 at 01:31:12:
I would check the rivet and part that is connected to the crosstube. The have been known to fail. If not that you may have to split the tractor and check the forks and rivet on the shaft inside. FO-4 fig 190 item 19 on outside and #10 on inside. also the throw out bearing and or fingers on clutch may be worn. Heck the clutch plate may be swollen up with oil. been known to happen.
