Re: 8n not firing
Posted by Rdavis on July 10, 2019 at 12:58:02 [URL] [DELETE] :
In Reply to: 8n not firing posted by Victoria on July 09, 2019 at 08:35:22:
Get yourself a test light and a good wiring diagram. On my 8n if anything arcs or shorts the coil fails. If you have power to the top of the coil and no spark this is likely your problem (as long as the wiring is correct). I assume you connected the electronic ignition to the top of the coil. Also I assume you gave converted to 12v.
