Re: Idle speed
Posted by Rdavis on July 07, 2019 at 22:28:06 [URL] [DELETE] :
In Reply to: Idle speed posted by Rdavis on July 07, 2019 at 20:30:48:
I can push the carb leaver down to the stop and it will idle rough around 400. This is with linkage connected. When running on its own the idle screw does not touch the stop unless I push it there. I have adjusted the idle mixture screw and it idles at about 1000 very well. But this setting is way off from the shop manuals 1 turn out.
