Re: steering wheel
Posted by Ed Goodman on July 01, 2019 at 14:18:49 [URL] [DELETE] :
In Reply to: Re: steering wheel posted by Farmer Dan on July 01, 2019 at 06:33:51:
Farmer Dan: Thanks for responding to me. I was able to remove the acorn nut in the center of the steering wheel fairly easily. That exposed a tube, but, you said I needed to remove the steering wheel. So, I'm assuming that the gear lube needs to be poured into the larger tube that the steering wheel sits on? You also said to scroll down the page for instructions on how to remove the steering wheel. I couldn't find any further instructions on the wheel removal. I tried to remove the wheel by just pulling up on it, no success. I tried a rubber mallet with no success also. There is probably a special wheel puller. Right?
Ed
