Re: early 9n gas tank
Posted by Steve Dabrowski on June 17, 2019 at 19:00:19 [URL] [DELETE] :
In Reply to: early 9n gas tank posted by cage on June 15, 2019 at 09:20:13:
Sounds like you may have a 1939 tank, these are different from all that came later on tractors with the hinged access door. The tank is narrower but not sure if it is also shorter. Center filler was 1939. If you have a true 1939 hood then it is an open question as to what you have. My 1941 tank will not fit in my 1939 hood, it is too wide (not sure about the length.
