Re: Brake cleaner?
Posted by K.LaRue-VA on June 16, 2019 at 10:50:07 [URL] [DELETE] :
In Reply to: Re: Brake cleaner? posted by Tom on June 15, 2019 at 10:18:19:
I sprayed up thru the wobble clip hole using the plastic tube from a can of wd40. Cant remember if the tube fit the spray valve or I had to swap the whole thing. Hosed it down good, turned the crank 1/2 turn and hosed it again. Put a pan under there to catch the stuff that drains out. Mine seemed to work a little better for a short time, but if motor oil or hydro fluid is getting on the clutch it will keep getting on there and causing problems until the tractor is split and seals replaced.
