Re: Sherman Trans Hole Template
Posted by Bob in KS on June 11, 2019 at 09:24:32 [URL] [DELETE] :
In Reply to: Sherman Trans Hole Template posted by Joel W on June 10, 2019 at 13:14:55:
This is how I did mine in a 51 side distributor 8N. This is for the overdrive version
to find where to drill the hole for the handle, put the Sherman in the case with a couple bolts to hold it. Take a pencil and rolling it around the shifter shaft pencil a circle on inside of bell housing. Drill in center of circle with progressively bigger holes, then take an air die grinder and a good stone and enlarge the hole to size needed.
