Re: 9n ford engine sleeves
Posted by Den N Ms on June 07, 2019 at 15:38:59 [URL] [DELETE] :
In Reply to: Re: 9n ford engine sleeves posted by Steve Dabrowski on June 07, 2019 at 11:37:14:
Steve,I would drain the block and remove the studs double nut them to remove one at a time.Coat the threads with some Permatex Aviation Form-a-Gasket and replace them.Then re torque them.Refill coolant start and check for leaks.Before taking the head off again.
