Re: Governor Settings
Posted by Rick D. on June 04, 2019 at 08:05:19 [URL] [DELETE] :
In Reply to: Governor Settings posted by Rick D. on June 03, 2019 at 21:16:34:
i guess its like this. new carb, linkage, and governor. is the length of the throttle linkage adjusted before the carb idle screw. i can manually operate the governor and it rotates to about the 1:oo(front) and dies. i am trying to determine where it should rest when idling. right now the idle screw does nothing in or out. i have read the I.T. manual and it only talks about the spring preload.
