Re: Activate three point on 8N with backhoe
Posted by Kirk-NJ on June 04, 2019 at 02:00:25 [URL] [DELETE] :
In Reply to: Re: Activate three point on 8N with backhoe posted by hs6160 on June 03, 2019 at 07:59:10:
On the 8n the lever than engages the pto must also be engaged to run the 3pt. If you push the clutch in it will disengage your pto/3pt. If nothing is happening with everything engaged then possible the valve on the pump might be stuck from years of not being used.
