Re: Governor Settings
Posted by JMOR on June 03, 2019 at 21:31:49 [URL] [DELETE] :
In Reply to: Governor Settings posted by Rick D. on June 03, 2019 at 21:16:34:
Throttle shaft and shaft bushings in carb most likely worn and as result any side tension as with linkage will pull it to side and not allow throttle plate to close because it touched bore.
