Re: Activate three point on 8N with backhoe
Posted by K.LaRue-VA on June 03, 2019 at 10:58:15 [URL] [DELETE] :
In Reply to: Activate three point on 8N with backhoe posted by hs6160 on June 02, 2019 at 09:53:23:
The upper lift arms and links should still be there. You may need to find an adjustable right lift link (with the crank handle) and the two lower lift arms. The tractor hydraulics only work when the PTO shaft is turning, so the lever on the left side that used to run the backhoe hydraulics is now restored to original function and only engages the PTO shaft and hydraulic pump. Touch control lever on the right side raises and lowers the 3-point lift. Small lever under the right side of the seat switches from position control (up) to draft control (down) for plowing.
