Re: Activate three point on 8N with backhoe
Posted by hs6160 on June 03, 2019 at 07:59:10 [URL] [DELETE] :
In Reply to: Re: Activate three point on 8N with backhoe posted by Kirk-NJ on June 03, 2019 at 01:53:44:
The handle is like the left one. It is a two function- step up - step down- arrangement. All external parts of the three point system - arms and activation handle- are there. Nothing happens when the handle is moved. The backhoe pump is externally mounted onto the PTO shaft and is activated by the lever on the left side of the tractor just below the driver seat.
