Re: Activate three point on 8N with backhoe
Posted by Kirk-NJ on June 03, 2019 at 01:53:44 [URL] [DELETE] :
In Reply to: Activate three point on 8N with backhoe posted by hs6160 on June 02, 2019 at 09:53:23:
Which sherman trans handle do you have? The one on the left would be a (2 position) step up or step down trans.If you have this handle since it's a backhoe it would probably be a step up. If your handle looks like the one on the right it would be a (3 position) combo.
Hard to say about the 3pt because we don't know what is left on the 3pt. The arms might have been taken off to install the backhoe depending on which backhoe you have. Photos would help. Was your backhoe run off the PTO pump?
