Re: Suggish after towstarting
Posted by Jack - Iowa on June 02, 2019 at 16:03:56 [URL] [DELETE] :
In Reply to: Suggish after towstarting posted by fritz on June 01, 2019 at 11:00:03:
I doubt your tow caused your problem. I'll agree with Bob and Farmer Dan on the ignition however if your gasoline is real old, that will cause a loss of power also. Not advised but I once ran some which was probably 5 or 6 years old. Had to adjust the mixture to get it to run.
Good Luck,
Jack
