Re: oil in coolant
Posted by Bruce (VA) on May 28, 2019 at 06:43:36 [URL] [DELETE] :
In Reply to: oil in coolant posted by Joseph Clour on May 27, 2019 at 20:34:25:
While water in the oil is always a problem, oil in an N radiator is not usually a problem.
Some anti-freeze has water pump lubricant in it. Or someone might have put stop leak in there. That's oil. Because it's a flathead, no oil lines are above the head gasket. But, you could have a leak in the head gasket which will produce a sheen on the coolant thanks to combustion gases. Or, if you have a leaky head gasket & the engine is burning oil, you will get more than just a sheen of oil in the radiator.
Any performance problems?
While a compression check can tell you that you have a gasket problem, itís not a sure thing. A leak-down test will tell you if itís leaking for sure.
Meanwhile, re-torque the head to specs: 50-55 ft lbs for nuts, 65-70 ft lbs for bolts. Torque it in the proper sequence.
