Re: 1951 8N-C radius rods
Posted by Kirk-NJ on May 26, 2019 at 02:58:38 [URL] [DELETE] :
In Reply to: 1951 8N-C radius rods posted by Chris Zuhn on May 25, 2019 at 23:50:22:
You can straighten them on the tractor by using some chain, a couple pieces of angle iron and a bottle jack or take them off and use a press. When they are bent bad it will effect the wear on the axle pin and bushing which may need to be changed out. Further wear will go thru bushing and waddle out the hole on the axle.
