Re: Engine rebuild with out splitting the tractor
Posted by Ultradog MN on May 25, 2019 at 03:17:17 [URL] [DELETE] :
In Reply to: Engine rebuild with out splitting the tractor posted by Peter on May 24, 2019 at 21:55:50:
I have done inframe overhauls but the big question before you start us: how is your oil pressure?
Without a split you cant do anything with the crank and on an N, the oil pump.
Also, with a flathead, unless you know someone you can bring the whole tractor to - or they will come to your place - you can't do much with the valves except lap them.
