Re: 8N-C hydraulic pump driven from front
Posted by TheOldHokie on May 20, 2019 at 19:47:25 [URL] [DELETE] :
In Reply to: Re: 8N-C hydraulic pump driven from front posted by Chris Zuhn on May 20, 2019 at 18:50:29:
If you are thinking live hydraulics on the 3pt keeping mind the max you can dump into the test port is a scant 3 GPM. Anything more will exceed the flow capacity of the exhaust valve and play havoc with lift control.
TOH
