Re: 8N-C hydraulic pump driven from front
Posted by TheOldHokie on May 17, 2019 at 05:31:50 [URL] [DELETE] :
In Reply to: 8N-C hydraulic pump driven from front posted by Chris Zuhn on May 16, 2019 at 22:09:33:
Crankshaft driven gear pump is common and relatively inexpensive solution. You have 25HP which will get you 10-15 GPM @ 2000 PSI. For intenive applications like a constant load hydraulic motor the reservoir size is likely the constraining factor. To really answer the question you need some idea of the duty cycle. What size reservoir do you need and where are you going to put it? In other words what are you going to power with the pump?
TOH
