8N Engine Vibration
Posted by Del Huebner on May 16, 2019 at 11:43:59 [URL] [DELETE] :
49 8N front mount distributor and 6 volt. Have an engine vibration most noticeable at half throttle. Disengage clutch and still does it. Checked and tightened fan belt, checked fan blades, water pump is tight and not leaking. Could it be the flywheel or the crankshaft pulley and why is it worse at half throttle? Any help appreciated.
