Re: Finally fixed ignition / switch problem
Posted by K.LaRue-VA on May 16, 2019 at 07:32:46 [URL] [DELETE] :
In Reply to: Finally fixed ignition / switch problem posted by Tom on May 15, 2019 at 18:43:03:
The switches are not sealed and replacements seem to be made cheaper every year. They do get crudded-up inside and cause problems, especially with a 6 volt system. My 8N now has a sealed marine-grade toggle switch for the ignition. No need for a key to run that one. The 2N has a "just like original" ignition switch from Dennis Carpenter that appeared to be made much better than the one it replaced.
