Re: New 641 electrical problem
Posted by NAA36663 on April 12, 2019 at 16:23:40 [URL] [DELETE] :
In Reply to: New 641 electrical problem posted by Mike in Michigan on April 12, 2019 at 15:55:43:
I agree with both posts below. I would also check the output of the generator. If I remember correctly, the 'charge light' is wired between the battery voltage and the generator output. If the generator is putting out voltage, the light goes out. If no genny output, there is enough voltage across the bulb to light. That's why it goes out shortly after starting the engine.
