Re: Ford NAA crankshaft won't drop to remove old rear seal
Posted by Joel on April 11, 2019 at 17:45:23 [URL] [DELETE] :
In Reply to: Re: Ford NAA crankshaft won't drop to remove old rear seal posted by K.LaRue-VA on April 11, 2019 at 14:29:52:
Thanks for the idea. I tried it, but the flex shaft was too flexible to use as a punch. I even used a mechanical pencil shaft to try to hold it straight while tapping it, but just wouldnt work. On the other hand, I flared out some of the wiring on a piece of the dremel flex shaft and put one end in my driver and used it like a drill. It almost works--very slowly cuts it out but gunks up too fast to make it very effective. Guess I'll just keep trying stuff. Hate to see it stuck in my driveway.
thanks
