Re: Front axle wear problem that should be looked into by 600
Posted by Rustyal on April 11, 2019 at 06:29:10 [URL] [DELETE] :
In Reply to: Front axle wear problem that should be looked into by 600 posted by Charles on April 10, 2019 at 17:16:23:
Normally the front axle parts are all stuck in place. And the only thing that needs repair is the center pin bushing and pin. You should not have to weld anything.
