Re: New 8n owner. Will not start
Posted by Bruce(OR) on April 10, 2019 at 12:25:13 [URL] [DELETE] :
In Reply to: New 8n owner. Will not start posted by Timothy Little on April 09, 2019 at 16:36:30:
Ether is a better starting agent than carb cleaner. By now the plug are flooded.
Pull them out and while they are out, pull and ground the coil wire and put your thumb tightly over the plug holes while cranking. You should have enough pressure to push your thumb off the holes. Dry the plugs, reinstall and shoot it with ether.
