Miss diagnos and change plan
Posted by Charles on April 10, 2019 at 11:58:23 [URL] [DELETE] :
In Reply to: plan posted by Charles on April 10, 2019 at 07:34:33:
The pin and threads in the mount were hammered up an down for 1/8" slop.The bearing was only .30 worn. Complete fix would require new support and new pin.
Farmerised it instead. Removed front clip and pounded pin in about 1/4" and bolted over front slot on pin instead of in slot.
Engineering error was not length of pin in threads, but two soft of metal of both pin and threaded support. I have also noted slop in pins and mount of wishbone rod pins and axle.
Not going to worry about it any more as should be good enough for my lifetime.Steers alright
