Re: New 8n owner. Will not start
Posted by steveVa on April 09, 2019 at 19:51:29 [URL] [DELETE] :
In Reply to: New 8n owner. Will not start posted by Timothy Little on April 09, 2019 at 16:36:30:
Check your wires firing order.
Is gas new or old?
Are plugs getting wet?
Is there water in the gas?
Did you clean carb??
Jets could be plugged.
Does your choke work?
Squirt a little fresh gas into carb and see if it pops.
Are you getting any pops at all? if not carb is plugged or float needle is stuck.
Did you pull plug in bottom of carb to see if gas flows thru??
