Krammin
Posted by Charles on April 09, 2019 at 07:03:54 [URL] [DELETE] :
I'm about to replace worn parts on front swivel pin, on late Ford 600, and not sure what I'm getting into and best method to do it.
Currently I have a 3/4" threaded bar thru the bushen pin, with a pipe larger then pin and pull it forward, with all attached yet.
Once I pulled the pin, I was hoping there would be enough up/down of axle to pull rear bushing and then front.
Is ther a better way, like removing radiator, then pull pin and then unbolt assembly from block and do a bench job?
Only bushings avaikable at steiner.
Was going to make center pin if worn and feasibility.
Advice appreciated.mail open
