Re: Too Much Fun
Posted by K.LaRue-VA on April 08, 2019 at 08:57:43 [URL] [DELETE] :
In Reply to: Re: Too Much Fun posted by Farmer Dan on April 08, 2019 at 05:58:56:
My second and third photos are in reverse order. I did have an implement on the back. The pallet forks raise a lot higher off the ground than a back blade, but that attachment is still what dug-in and killed forward progress. When the front tires went up the bank the attachment dug into the creek bed. When I tried to back out, the forks went into the bank behind me. Grrr, remove the implement and drag it out of the way. Then the tractor would roll back and forth far enough to get it out of the original ruts. It should be ok till I can get down there with the winch to help pull it thru the muck. I will have to haul some rip rap down there to fill holes and stabilize the crossing.
