Re: Circle Mark - Is this the one?
Posted by deanostoybox on April 01, 2019 at 16:03:34 [URL] [DELETE] :
In Reply to: Circle Mark - Is this the one? posted by Kimberly on April 01, 2019 at 14:42:39:
doesn't look like it. ones I'm talking about would be inline with the bot holes, about 1/4" in diameter, and no marks inside.
from the file "Lift No Jig Adjustments.pdf" in the section "Control Arm Adjustment":
(3) Find the bolt hole that is located just behind the
hydraulic touch control unit. Measure 1.7 - 1.75 inches
forward from the front edge of this bolt hole. Make a
mark on the mounting flange at this location
That is where it would be. If not there you don't have them. Some do, some don't.
If the mark were there you would not need to make that measurement:-)
