Re: Remotes
Posted by TheOldHokie on April 01, 2019 at 14:54:47 [URL] [DELETE] :
In Reply to: Remotes posted by Daniel Jinkens on April 01, 2019 at 08:15:24:
There are a couple different ways. IMO the easiest is the simplest. Cut the pressure tube in half just below the pump, put a couple tube fittings on the ends, and plumb an open center valve into the middle.
TOH
