Re: Remotes
Posted by K.LaRue-VA on April 01, 2019 at 10:50:23 [URL] [DELETE] :
In Reply to: Re: Remotes posted by Farmer Dan on April 01, 2019 at 09:51:46:
I've seen a bunch of them done just like that but they probably shouldn't be using plumbing parts rated 300 PSI on hydraulics rated 2000 PSI. Fortunately, my lesson was only a boot full of very warm oil. By the time I got that hot boot peeled off my foot was red but not burned. Losing 3 gallons of nearly new combo fluid bothered me more than the oil-soaked sock and boot. Those pot metal plumbing fittings at the home stores are also being made a lot cheaper than they used to be. What worked 40 years ago probably won't today.
This is the fitting that broke. The inset is a steel hydraulic fitting that should have been used.
