Re: Leaking Hub Seal - Follow Up
Posted by Kimberly on March 31, 2019 at 14:25:54 [URL] [DELETE] :
In Reply to: Leaking Hub Seal posted by Kimberly on March 29, 2019 at 14:38:39:
OK, since it was mentioned the nut could be loose, I decided to check; using a very large pair of channel pliers, I was able to turn the nut. I need to get the proper socket size. What is the size?
My concern now is that I might have damaged something by using the tractor with a loose axle nut. Is it possible I have created some issues now? Please advise me. I had no idea to check the nut since I have never done any work on the wheels.
