Re: Leaking Hub Seal
Posted by Dead Eye Dave on March 30, 2019 at 05:35:18 [URL] [DELETE] :
In Reply to: Re: Leaking Hub Seal posted by R Geiger on March 29, 2019 at 15:06:28:
Good morning Kimberley. I remember when I had to tighten one of these nuts.....I was advised to use a two foot ratchet and to stand on it. I weigh 200 pounds so the thought was that 200X2' =400. It worked. Now I know better than to ask what you weigh but, using that equation you can figure it out. I had a breaker bar and a piece of pipe as an extension. Not hard. I believe I borrowed a socket and 3/4" ratchet set. Good luck. Assuming you weigh 100 pounds, you need a 4' bar length. Hee hee.
