Re: Draft Control Plate - Opinion Please
Posted by Kimberly on March 29, 2019 at 11:28:56 [URL] [DELETE] :
In Reply to: Re: Draft Control Plate - Opinion Please posted by Kimberly on March 28, 2019 at 22:18:18:
I read through Zane's adjustment procedure. I might wait on replacing the plate as it is slightly worn; see photos of lots worst. If I can't get the draft control adjusted then I will remove the draft control yoke and replace. Do you guy's agree or should I order the new plate from Just8Ns? What would you do it if was your tractor?
