Re: I only removed two
Posted by Kirk-NJ on March 19, 2019 at 01:41:12 [URL] [DELETE] :
In Reply to: I only removed two posted by Kimberly on March 18, 2019 at 22:58:13:
The drain for the rear is a small square head plug unlike the other two plugs. It sits just it front of the drawbar bracket. If no drawbar then in front of the two mounting hole. If your drawbar is in further you might not see it. You might need to remove the drawbar for access.
