Need a bit of help
Posted by Kimberly on March 18, 2019 at 17:36:49 [URL] [DELETE] :
This job is going to be a bear; rusted bolts everywhere (hey, that rhymes). Fluid is drain; trans bolt was a bit hard to get out. I went to take the right side running board off and one of the bolts appear striped; the bolt came out; it was loose to begin with and the threads look buggered; fix, drill out and tap larger or just some locktite? That worry later. Went to take the bolts out of the front of the running board and they bolt is just going to spend. Thought, why not take the radius arm off to take the front bracket off? Well, I took two bolts out but now what? Is the socket cap suppose to now come off? Or am I just making a bigger problem? Might have to walk away a bit.
