Re: Will this work for lifting the lift cover?
Posted by carlintexas on March 03, 2019 at 12:17:48 [URL] [DELETE] :
In Reply to: Re: Will this work for lifting the lift cover? posted by Kimberly on March 03, 2019 at 11:18:19:
Your winch will work fine on the top cover but were it's mounted is the problem. I used the exact same winch to work on my top cover ,but it was supported much better.You need to be aware when lowering it won't stop instantly.
