Re: Will this work for lifting the lift cover?
Posted by Kimberly on March 03, 2019 at 11:21:34 [URL] [DELETE] :
In Reply to: Re: Will this work for lifting the lift cover? posted by PatrickB on March 03, 2019 at 11:15:57:
Yes, I guess not a good idea. I will probably stand on the running boards and just lift the cover up and clear the rod, then flip it over and set it back down. Then climb down off the tractor, go around to the back, then lift it off the case onto a table.
