Re: Will this work for lifting the lift cover?
Posted by Kimberly on March 03, 2019 at 00:33:54 [URL] [DELETE] :
In Reply to: Re: Will this work for lifting the lift cover? posted by Bruce(OR) on March 02, 2019 at 23:07:07:
The cover with cylinder is that heavy? Maybe I need one of those engine lifts for this job. I think the ceiling height is 10 feet so I could get some 2x4x10s and put on either side; notch the top and then tack in with a drywall screw to keep in position. The only problem with the engine lifts is that they are hydraulic and it is hard on some to lower; turn the screw out too much and it just drops on you and that would be bad. Are there any strong men that would like to lend a hand on this job :-).
