Re: Here we go AGAIN...
Posted by 49er swGA on February 28, 2019 at 18:28:58 [URL] [DELETE] :
In Reply to: Re: Here we go AGAIN... posted by Ultradog MN on February 26, 2019 at 09:32:47:
You are correct, the bearing is demolished, for SURE!!
You`re the voice of experience Ultradog!!
The other bearing in top of the cover/Tube is also MIA leaving only pieces of it...
I got it apart and cleaned up for new parts to be installed...
Local NH/FORD has the lower bearing in stock, but the upper is`nt in stock...
seals were`nt leaking, so it`ll be $14 to repair for the lower end...
As I read the how to on this, I remember pulling the bolt & oiling it once on either this one or the 49er...
Thanks again,
Dennis
