Vane type Hydraulic Pump Kit for Ford NAA
Posted by Steve Diehl on February 25, 2019 at 13:21:00 [URL] [DELETE] :
I have done the testing to confirm that the pump is too wore out to produce enough pressure and just ordered the 5/8 Thick Vane Type Hydraulic Pump Kit from Yesterday's Tractor. Does anyone have experience with this kit? I see it comes with the body/rotor/vanes along with 2 O-rings. I am not sure how much I will need to take apart when I receive the kit and am wondering if I might be needing the seal and any gaskets that show up on the exploded parts view I found online. The pump does not leak now. I can still do some snow plowing (blade on front with cable going back to hydraulic arms) and do not want to take the pump apart until the kit arrives. I can plow for 15-20 minutes at a time before it stops lifting the bade. Any advice regarding installing the kit would be appreciated.
Thank you,
Steve
