8n tractor
Posted by Emilio on February 22, 2019 at 12:37:52 [URL] [DELETE] :
Bought a tractor, it ran for a couple of hours then died, could not get it started,
some other problems were starter went out, flywheel ring was broke, I replace started, flywheel ring, point condenser, coil, wires, cap,new carburetor. Timing was way off, so I messed with it for a couple of weeks, finally got it to start, for a couple of weeks it would turn over but would die as if it was not getting any fuel, the problem was the hose from carburetor to air cleaner, it was sucking air, I put tape on end of hose and now tractor starts, sometime I do not even have to use the choke, it starts real easy, it will sit and idle like forever, Now my problem is when I put it in gear it dies, I have checked point gap, plug gap, I know the carb is not the problem, maybe someone has an idea what is causing it to die. Sorry for long post.
Thanks
