Re: Douglas
Posted by Farmer Dan on February 20, 2019 at 15:56:14 [URL] [DELETE] :
In Reply to: Douglas posted by Rick on February 20, 2019 at 15:38:07:
How is the fuel flow to the carb? Take the plug out of the bottom of the carb and see if it will fill a pint jar in a minute or two. If that looks good then check you points. Are they still gaped correctly or did the rubbing block wear down so they won't open anymore?
