Re: 1954 NAA Hydraulic Problem
Posted by JMOR on February 19, 2019 at 15:59:04 [URL] [DELETE] :
In Reply to: 1954 NAA Hydraulic Problem posted by Steve Diehl on February 19, 2019 at 10:44:09:
In addition to info that TOH provided, note that the pressure which you measure is proportional to the load being lifted. You should only see max pressure if load is too heavy to lift or if you chain the lift arms down.
